Intel Core i5-9500 Review
Written by Antony Leather
May 24, 2019 | 10:00
Tags: #coffee-lake #x299 #z390
Companies: #intel
Deus Ex: Mankind Divided
Publisher: Square Enix Holdings
We test using the 'High' preset and run the built-in benchmark (hidden in the 'Extras' menu), as it is very consistent. We also rely on the game's own frame rate counter since FRAPS does not currently work with this game when using DirectX 12. We've actually found that your experience in-game will typically be with frame rates a little higher than the average frame rate from the benchmark.
Far Cry 5
Publisher: Ubisoft
We test using the game's built-in benchmark that runs through various zones of the Far Cry 5 world and has a detailed readout of performance, where we record the minimum and average frame rates. We use the 'Ultra' preset with an unrestricted frame rate at 1,920 x 1,080 with all other settings at default.
3DMark Time Spy (CPU Test)
Publisher: Futuremark
Time Spy is a DirectX 12 benchmark that runs at 1440p. It is designed to properly utilise the advantages of the DirectX 12 API. The benchmark is available for free, but you'll need to pay to change any of the settings, including the resolution. We use the default settings, so you should easily be able to compare your score - just remember that we're reporting here the individual CPU Test score rather than the overall score.
VRMark
VRMark is another synthetic GPU benchmark from Futuremark, this time specifically designed to assess a system's ability to handle VR gaming, although no VR headset is required. The Orange Room test assesses whether a system is capable of meeting the current minimum requirements for an Oculus Rift or HTC Vive VR headset. We run it at default settings, so users can easily compare scores here to the free version of this benchmark where settings cannot be changed.
null
